1979 300SD Rod Knock?
Old Mar 8, 2010 | 06:29 PM
jim x 3's Avatar
Default 1979 300SD Rod Knock?
I've acquired a parts car - 1979 300SD
It's complete. I haven't heard it run or crank. I was told it has a rod knock.
I have been told that a bad injector can cause similar symptoms. I don't know if this is true or not. What is the most expedient way to determine the condition of this engine?
Thanks,
Jim Jim Jim
Old Mar 9, 2010 | 11:52 AM
machnist1's Avatar
Default rod knock
Hi Jim
I have a 1983 300SD with a similar problem.
A Mercedes tech. told me it could be a bad
precombustion chamber,as well as a injector.
He said a carbon buildup in the chamber could cause the noise.
I got mine to run, (very rough). It quit running after I changed the oil
and added Marvel Mystery Oil about a pint.
The car is in real good shape. A silver blue color with blue leather.(No rips)
I also have a 1982 300D. Cherry condition. 376K.
Good luck.
James
Jimbezy
Mar 12, 2009 05:41 PM
sfk
Dec 8, 2007 07:25 PM
kallejohnson
Aug 15, 2007 03:48 PM
chrissie10027
Nov 13, 2005 04:06 AM
