Detailing Discuss detailing your ride inside and out here.
cleaning scuff marks on door sill
Old Jan 15, 2007 | 11:24 AM
dixiesothercar's Avatar
Default cleaning scuff marks on door sill
My e350 has a stone interior (real light color) and I have been unable to clean the scuff marks (from shoes) on the hard plastic trim or the soft edging. Tried soap & water, carpet cleaner, vinyl cleaner to no avail. I would appreciate any surefire solution. Also, my light color mat on the front passenger side has black greasy stains (probably from a slovenly passenger) that don't come out with carpet cleaner.
Old Jan 15, 2007 | 11:34 AM
SunGuy62's Avatar
Default RE: cleaning scuff marks on door sill
dixiesothercar.
My interior is also light, Java, and for marks on the vinyl or plastic, I first try Simple Green with a soft bristle brush. If that doesn't work, then Meguiars Heavy Duty Vinyl Cleaner found at autopaint supply houses. As for the mat, I'm lazy, so I vacuum, spray the stain/grease with Shout or Spray and Wash and throw it in the washer...works for me.
Bob
Old Mar 9, 2007 | 01:21 PM
Mercedes Benz of FL's Avatar
OK;
I'll say it again;
I'll give you a tip; but it comes with a
WARNING!
Try:
Mr. Cleans-"Miracle Eraser"
I assure you; it WILL remove the black scuff marks,[sm=happybounce.gif]
black marks or heavy build up in your car
It does scratch somewhat so be careful.
This stuff WORKS! like nobodys business
Good Luck and let us know how it turned out
It's in Home Depot
Old Apr 27, 2007 | 07:44 PM
allikanbe's Avatar
Tried it. Works great. Thanks. I had to order new floor mats to match the new-looking sills.
pkmaven
Jun 14, 2021 08:37 AM
benzrookie
Jan 8, 2007 12:43 PM
raycyclone
Dec 12, 2006 08:56 AM
moooky
Nov 14, 2006 11:18 PM
pkmaven
Aug 17, 2003 11:22 PM
