cleaning scuff marks on door sill
My e350 has a stone interior (real light color) and I have been unable to clean the scuff marks (from shoes) on the hard plastic trim or the soft edging. Tried soap & water, carpet cleaner, vinyl cleaner to no avail. I would appreciate any surefire solution. Also, my light color mat on the front passenger side has black greasy stains (probably from a slovenly passenger) that don't come out with carpet cleaner.
RE: cleaning scuff marks on door sill
dixiesothercar.
My interior is also light, Java, and for marks on the vinyl or plastic, I first try Simple Green with a soft bristle brush. If that doesn't work, then Meguiars Heavy Duty Vinyl Cleaner found at autopaint supply houses. As for the mat, I'm lazy, so I vacuum, spray the stain/grease with Shout or Spray and Wash and throw it in the washer...works for me. Bob |
OK;
I'll say it again; I'll give you a tip; but it comes with a WARNING! Try: Mr. Cleans-"Miracle Eraser" I assure you; it WILL remove the black scuff marks,[sm=happybounce.gif] black marks or heavy build up in your car It does scratch somewhat so be careful. This stuff WORKS! like nobodys business :) Good Luck and let us know how it turned out It's in Home Depot |
Tried it. Works great. Thanks. I had to order new floor mats to match the new-looking sills.
