C200 K Coupe & Nokia 6310i
Thank you for all that info on my car. You must know more about it than my local MB dealer. However I have had no success with the 6310i working in the cradle, but I did try a friends 6210 which worked perfectly, using the dash display etc. and all ther other in car features.
The firmware on my 6310i is v5.2X and i know the newest firmware is v7.0. If I get it upgraded to v7.0 do you think that will make it work?
Hi guys, I'm going to put my 2 cents worth in now. Unfortanately, your car, being a 2002 model, doesn't have what is called a UHI interface. If it did, you would just need to change the handset holder and away you go.
I have had experience in changing these phone systems from a 6210 to a 6310 and can tell you that your dealer is correct to say that you need a new control unit. The control unit is hidden away in the boot of the car and is called a CTEL interface. There is a different interface used for the later 6310.
Let me know if you need more info.
Have checked everything including the card in the back of my service book and i agree that 6310i (v5.22) should work. Also just tried another 6310i with no luck. What are your suggestions. Should i visit my dealer and get them to check out the cradle?
thanks
thanks
No it won't be the cradle if the 6210 works. You need an interface unit, and, Oh, look, the phone interface you need has just popped up on Ebay in Australia. Isn't that where your from?
http://cgi.ebay.com.au/ws/eBayISAPI....tem=5802146646
Contact Steve @www.MBENZNL.com re the phone problem..He can get you whatever it takes to make it work...PSEs or cradle
Steve sells MB UHI kits and PSEs for the 6310I ..I Have The 6310I and It Works Great!
Then add a V/R kit for hands free!
Hi there.
I have a Mercedes C-class with an original car kit for Nokia 6210, and I tried to conect a Nokia 6310i, but the phone does not recognize the car kit, charging only batery.
Is there any solution for this problem.
Hi there.
bounce
May 8, 2010 10:59 AM
200, 2011, 6310i, 6310imercedes, c200, coupe, features, mbcar, mercedes, mercedesbenz, noka, nokia, nokia6310i, processing, telefonu
