Audio/Visual Electronics Wired up? Got a cool radio? Everyone's got some sort of electrical modification. let's hear about it.
99 SL500 Power Antenna
Old Oct 14, 2006 | 06:54 PM
raymond191's Avatar
Default 99 SL500 Power Antenna
Has anyone had experience in removing their power antenna on a 1999 (or there abouts) SL500? Mine is not working and is stuck in the up position which makes it hard for me to use the cover on the car. I have open access to the antenna, but I am having a problem determining how to disconnect it from the top of the unit (where it goes through the fender). The instructions I have are very general and say "Unscrew union nut", Pull off cover, unscrew antenna lead, disconnect electrical, remove automatic antenna, remove spacer, etc. I guess my question is - is the union nut the nut that holds the mast in?
When I remove that nut the cover does not seem to want to come off easily and I don't want to force it; but even if I got it off it doesn't seem that, that would loosen the antenna enough to enable me to release it down into the trunk.
Any help would be appreciated. Thanks
Orb the Impaler
Sep 23, 2008 11:33 AM
idecelr8
Jul 6, 2008 01:26 PM
CollectiveSoul
Feb 19, 2007 03:15 AM
techteam
Jan 20, 2005 02:48 AM
Randy
Nov 10, 2004 11:03 PM
