information about desiel engine models
hi there, Thank you in advance for any replies to my questions, your generosity is much appreciated.
So, in short i am looking to purchase a diesel van for a new business. i am wanting to make it be able to run on bio fuel and svo.
I have being given the advice to look for a engine that has;
- a mechanical injector pump
- not use a common rail injection, but can be indirect or direct injection.
- not have a diesel particle filter.
got all that! ; )
So my question
-Does anyone know which diesel engine (s) would comply with the specs needed?
- if there are, what the latest complying model would have been
- any with turbo?
- any other information would be greatly appreciated !
thanks again
marcus
got all that! ; )
So my question
- any with turbo?
thanks again
marcus
The only issues I ran into running Bio-diesel was the rubber fuel lines.
The Bio-diesel would make them soft and then they would leak, you can replace
the lines with a synthetic rubber that stops the all of that , I had to replace the
injection pump seals also after 80,000 miles with Bio-diesel safe seals.
This was on a 2003 VW TDI and I would up to 100% Bio-diesel.
I could run 20% with out taking a mileage hit.
Hoses, Seals and O-rings made of Viton.
For the OP; read up on the Winter use of Biodiesel.
axel_g
Nov 7, 2011 06:41 PM
Lindy
Jun 17, 2004 01:21 AM
