use of regular fuel in 95' V12 SL600 AMG
Old Jun 12, 2010 | 03:49 PM
twooldfarmers's Avatar
Default use of regular fuel in 95' V12 SL600 AMG
will the knock sensors allow continued use of regular fuel in this 10 to 1 ratio R120 (R 120) motor
Old Jun 13, 2010 | 08:43 PM
96SL500's Avatar
From: Manatee County, Florida- Sarasota mailing address
I found my 96 SL500 gets better mileage with premium than regular. Since my local station charges 20 cents more per gallon for premium, that means the 20 gallon tank costs $4 more to fill. Depending on your cost, this is about a gallon and 1/2. Check mileage both ways, I think you will appreciate the added performance and improved mileage, I do.
Old Aug 6, 2010 | 04:38 PM
draig's Avatar
as a former owner of an 11:1 ac bristol, i've always believed that 10:1 & up compression ratios should use premium fuel. if you are satisfied with the performance and have no knocking i will be surprised.
SteveFrench
Oct 16, 2014 10:20 PM
twooldfarmers
Jun 12, 2010 03:46 PM
mercedesml500
May 16, 2006 11:54 PM
makaveli
Nov 7, 2003 04:28 PM
