FAN CLUTCH failure?
Old May 21, 2010 | 12:45 PM
Naffi SL500's Avatar
Default FAN CLUTCH failure?
hello guys...i drive a 500SL '93.....could a slow fan clutch send the temp. up high to 110? ..and maybe to the H level ? or is it smtn in the engine..it may go up top if i leave the AC on..but without ac..temp is stable.. so plz help ! ...and thank u ..
Old May 21, 2010 | 07:18 PM
Anyone??
Old May 22, 2010 | 09:57 AM
ab4jy's Avatar
Default fan clutch
how is the engine temp at highway speeds ?
glen
Old May 22, 2010 | 01:31 PM
one way to tell if the fan clutch is bad is to try to stop it while is moving. it should not be able to be stopped. if you can slow the fan with your hand usually means its weak. becareful....use a rag or a heavy glove and try to stop the fan. you can try to engauge the fan clutch by putting a large towel in front of the radiator so air cannot flow to the engine then raise the rpms to 4000 rpms for a while until the engine gets hot and the fan will kick on or should kick on. if the clutch is good the fan will engage abruptly . then you can try to stop the fan. that was 1 way i was tought to check the fan clutch. i guess what Bill F stated could work also.
Old May 22, 2010 | 09:43 PM
Bill F's Avatar
I would practise typing with one hand before grabbing the moving fan.
I would run the car until it was really hot and shut it off, tie a string to the fan and the body, and restart engine. If the clutch works the string should break, unless you use to strong a piece.
Clean the radiator and the condenser coil with a garden hose first.
Bill
Old May 23, 2010 | 12:38 PM
Default Still
Thank u for the good replies...the fan clutch was very bad...it freewheels when i just push it a little..more like 5 or 6 spins... so i changed it...and made the front fan stronger..it got better.. the thermostat is new...and still highway temp is 105 or 104 WITH AC...the ENGINE-RADIATOR hose has no pressuere..like not hard... i dont know what the hell is happening.... thank u guys again
punk760
Dec 15, 2008 12:53 PM
lxshk
Aug 7, 2008 08:28 PM
sleepdoc38
Jun 16, 2005 07:05 PM
aharley1
Jan 15, 2005 02:15 PM
Brody
Jan 28, 2004 08:55 PM
