2000 S500 Air Suspension
Old Sep 28, 2009 | 10:40 PM
Jaddison's Avatar
Default 2000 S500 Air Suspension
Hello,
I have an air suspension question. 3 of 4 tires are lifting up fine, but rear passenger is rubbing the fender. To start off I have checked the fuses, and the compressor runs fine. Cant hear or see any leaks on the passenger rear. So is there a valve or somthing between the bag and air line that can restrict air flow? or somthing else i should check?
Thank you in advance for any help.
Josh
Old Oct 28, 2009 | 04:13 PM
vinciegirl's Avatar
Default re: suspension
My husband owns a 2000 S500 (he's a mechanic) and when he first got it he had the same problem with the left front. He took it to the dealer for a diagnostic and $125.00 later with a quote for $9,600.00 to fix the problem, we were told that the strut needed replacing.
We bought the star scan tool and to our surprise it was the left front height/level sensor. $240.00 and the problem was fixed. Our regular tool could not scan it but at least we can perform diagnotics on all benz now.
Old Oct 29, 2009 | 10:21 AM
Jaddison's Avatar
thanks for the response ill give that a look.
Old Oct 31, 2009 | 02:15 PM
BlackWolf's Avatar
the stealership strikes again.
The sad part is that 9,600 dollars later, the problem probably would not have been fixed.
blkbenz
Mar 13, 2012 09:00 AM
umoms
Dec 31, 2009 09:56 PM
LAKERSS3
Jan 16, 2009 04:10 AM
md11king
Jun 20, 2008 10:59 AM
gixxer
Feb 14, 2008 09:49 PM
