CD changer problem
Old Sep 6, 2009 | 12:32 AM
CAK's Avatar
CAK
Default CD changer problem
I have recently purchased a 99 SL 500 wih a cd changer in the trunck, but when I put a disk in and push the cd on the radio, i keep getting a message thet the changer is empty, even when i put in a cleaner disk will give the same message.
Is this a typical problem with the trunk unit or should I look for an in-dash after market cd changer that I can also hook up my cell phone into and will fit in the radio space, any suggestions are welcome. Thanks
Old Sep 7, 2009 | 12:03 PM
ab4jy's Avatar
Default cd changer..
i have a friend with a 99 sl that had the same prob intermittently,,,finally gave up
completely...i have a 2003 that will sometimes go goofy and by ejecting the cd cassette
cart..it will reset...
i suspect if it has become a permanent problem, try removing (unplugging ) the cables at the trunk unit and wiggle them to eliminate the possibility of a corroded connection,
otherwise, replacement would probably be next step..my friend found one on ebay that i
replaced for him in about 15 minutes, you can do the same...its very easy.
he has not had any further bproblem..
or........you might consider an ipod with fm link to your radio..
glen
Old Sep 7, 2009 | 12:14 PM
ab4jy's Avatar
Default cd changer
back again....i guess this is ok to post, if not i apologu=ize.
i found a unit on ebay...go to item 380155134037
if interested.
glen
Old Sep 7, 2009 | 12:28 PM
1970ls5's Avatar
I have a CD trunk changer and Becker head unit for sale from my 93 SL500 for $100.00 for both units if you are interested, can ship it for free anywhere in the U.S. on UPS also. You are welcome to call me at 305-310-3866 if you are interested. Dave
Old Sep 7, 2009 | 10:12 PM
CAK's Avatar
CAK
thanks for the tip, I will try to clean the wires and check for corrosion
trulegend
Oct 5, 2006 03:28 PM
Benzaholic
Feb 22, 2006 06:38 PM
sccchiii
Feb 17, 2006 02:17 PM
arm0rallday
Sep 25, 2005 12:41 AM
