ML 320 Power Steering leak
Old Sep 2, 2009 | 11:25 AM
vsalico's Avatar
Default ML 320 Power Steering leak
Power steering unit has a leak on the upper section of the pump. I have tightened the bolts on the rear of the unit and had the rubber hose to the radiator replaced but still needs some fluid each week. I also tried some Lucas Stop Leak but it did not work.
Can repairs be made without removing the pump. Thx.
Vince
Old Sep 2, 2009 | 11:48 AM
This could be just bad or aged O-ring around the neck of reservoir connected to the pump. I believe you need to remove only one screw and snap ring from the neck to get the reservoir out, but syphon the fluid out first.
Old Sep 15, 2009 | 09:43 PM
chaisone's Avatar
I bet the hose slipped off of the nipple at the radiator.
Old Sep 17, 2009 | 04:56 PM
iceman0941's Avatar
I had the same problem on my 2000 ML320, and it was the O-ring around the neck of reservoir connected to the pump as mbenz80 said. It costed me a few bucks, and the problem was solved.
Good Luck!
pgarlsvc
Oct 22, 2012 09:03 AM
teal854t
Oct 28, 2008 05:20 PM
nvestor88
Sep 6, 2006 03:36 PM
