98ML320 - Radio malfunction
Old Jun 24, 2009 | 08:01 AM
Ronsr's Avatar
Default 98ML320 - Radio malfunction
Does anyone know what the problem might be with my radio? It was working fine and now I no longer can get AM stations, Weather Mode, nor scan function. I have no long range frequency pick up on the FM channels. The only FM that I pick up is when I am in close distance to a major frequencies. Has the radio gone bad or is there an antenna problem? Any help will be appreciated, thanks.
Old Jun 24, 2009 | 09:50 AM
Check the antenna amplifier connections (ground) under door panel in rear hatch (behind rear license plate underneath the center brake light). Mercedes has repair campaign for it, wire lug installed over the door paint and some W163 radios will loose antenna signal because of it.
Old Jun 24, 2009 | 09:07 PM
Ronsr's Avatar
Is it necessary to remove the entire rear panel on the inside inorder to access it? Or is it accessed from the outside near the license plate?
Old Jun 25, 2009 | 12:06 AM
Yes, you need to remove the plastic panel with about same procedure as removing any door panel.
firstfeather
Feb 27, 2010 02:11 PM
yogiho
Jun 3, 2008 06:07 PM
Hecvar85
Apr 15, 2008 10:53 AM
TK
Mar 31, 2005 06:34 PM
jab
Nov 8, 2004 05:30 AM
