1991 300e 24 valve hesitant on acceleration
Old May 3, 2009 | 07:51 AM
vednam99's Avatar
Default 1991 300e 24 valve hesitant on acceleration
My car has hesitant acceleration on take off from standstill. I have changed the injectors, leads, s/plugs which has improved it but not eliminated the problem. It also becomes worse after "heat soak" of the engine. However, there is no problem before the engine warms up fully. Please help...I wonder if its an electrical problem of some sort. Thanks
Old May 3, 2009 | 09:35 AM
iluvjesus's Avatar
Do you think this is a problem with the transmission? Have you change the transmission fluid yet? Any difficulty putting into first gear? Another simple thing is the transmission mount need to be changed.
Old May 3, 2009 | 09:49 AM
iluvjesus's Avatar
This is a DIY for transmission mount replacement on a W210, but it is similar to yours.
http://www.benzworld.org/forums/w210...placement.html
Old May 3, 2009 | 10:10 AM
vednam99's Avatar
Default trans fluid
has been changed but no difference unfortunately...
Old May 3, 2009 | 10:43 AM
iluvjesus's Avatar
Consider searching/asking in this forum, you should be able to find the answer.
http://www.benzworld.org/forums/w124-e-ce-d-td-class/
Old Sep 3, 2009 | 03:26 PM
vanisle's Avatar
Default hesitant on acceleration
Have you re-adjusted your fuel to air ratio...after the parts replacement
Old Sep 4, 2009 | 05:05 AM
vednam99's Avatar
Default Fuel Air Mix
Hi. I had it adjusted some time ago. apparently the car was running slightly rich. Fuel-air ratio was adj the proper way and car drives really well now. Could have saved me some $ if I had known this!!
bbrinkw
Jul 16, 2011 07:36 PM
thalbrooks
May 29, 2011 08:38 AM
RicLonsdale
Jul 18, 2010 04:58 AM
Collector_tjs
Oct 4, 2007 06:41 AM
wagits
Dec 27, 2006 06:43 PM
