E430 won't shift from drive to reverse
Old Jan 18, 2008 | 07:34 PM
markwill's Avatar
Default E430 won't shift from drive to reverse
The car drives fine, when I tried to back it into my parking spot today the gear selector won't go into reverse.
Old Jan 18, 2008 | 11:44 PM
Default RE: E430 won't shift from drive to reverse
is this problem a one off or is the problem still present.
Most likely the gearbox selector module.
Could be adjustment but most likely "soft drink" into the works adjacent to the selector lever.
Get the vehicle ECU scanned and this will confirm diagnosis before spending money on new parts.
Stuart.
Old Jan 19, 2008 | 06:50 AM
markwill's Avatar
Problem is still present. Took apart the center console and had a look around, it's pretty clean and I know I didn't spill anything.
Old Jan 19, 2008 | 12:11 PM
Won't go into Reverse??
You have to go thru R to go from P to D.
Do you mean you put the lever in R but the car doesn't move or what please?
If the lever wont move into R I assume you must have started the car in N
I;m confused.
Stuart.
Old Jan 19, 2008 | 12:24 PM
markwill's Avatar
The car was driving fine, I had actually just backed out of my parking spot at the grocery store. I drove home, less than a mile and when I went to back into my space the gear shifter wouldn't go into reverse. The car was already running and in drive. It will move up to neutral, but not reverse and therefore not park.
Old Jan 21, 2008 | 12:43 PM
markwill's Avatar
I took the car back to the dealer and they ended up replacing the ECM, electronic control module aka TCM or TCU. I've heard it called all 3 over the course of this weekend and I'm still not sure what the technical name is for it is. Basically they replaced the electronic shifter unit. Noone at the dealership had seen it get stuck from drive before. Since the car was under warranty it was no cost to me![/align]
concord
Jun 16, 2020 02:09 AM
flaandy
Nov 3, 2012 10:36 AM
Mkiz
Nov 1, 2010 02:38 PM
winstonsmith6076
Sep 12, 2006 03:33 AM
bass1175
Sep 23, 2004 02:09 AM
