Manual key won't open boot - stuck with no battery...
Old Nov 4, 2007 | 06:35 AM
potterg's Avatar
Default Manual key won't open boot - stuck with no battery...
Looks like my battery has died and I've tried my three manual keys to open the boot lock. Key goes in (after greasing) but does not turn at all. As a result, can't get to battery. Is there another manual release for the boot in the car ?
Old Mar 10, 2008 | 03:27 AM
tomkuehn's Avatar
Default RE: Manual key won't open boot - stuck with no battery...
I have got exactly the same problem. This is already the second time. Last time around I was lucky as the back seat rests weren'tlocked back into thetheir positionso I could crawl from the inside of the car into the boot. Fortunately the manual key works with the front door. This time around I am stuck. I bought a solar-powered trickle charger which I plugged into the cigarette lighter, but after a few days I still couldn't see any indication of successful charging activity. I have heard that with some cars the cigarette lighter connection to the battery is only live if the key is in position one. This is a double whammy Catch 22. The only other thing I can think of is to find a connection somewhere under the bonnet where I could hook up the trickle charger.
Have you had any luck?
Thanks,
Tom
Old Mar 24, 2008 | 07:22 PM
ilovemyclk's Avatar
the manual key on my car will open the truck to allow access to the battery but only after alot of stressful fiddling with it. it takes thick strong fingers so i had to find a man to do it for me but eventually we got it open
Old Apr 23, 2008 | 02:27 PM
Whisper64's Avatar
I agree with ilovemyclk. I've had the same issue with the dead battery, I called MB mobile services and he manhandled the manual key: Trunk opened!
Old Jun 24, 2009 | 07:58 AM
ilovemyclk's Avatar
Default again
hey it happened to me again but this time I had a pliers...totally way easier it was a sinch
kk2
May 15, 2015 02:49 AM
Goldengirl1
Nov 8, 2012 07:28 PM
eliteproxy
Feb 26, 2012 02:28 PM
krisb60
May 26, 2011 03:13 PM
shamza
May 7, 2008 02:01 AM
