How to open the boot S320 with manual key if battery is dead?
Old May 1, 2008 | 11:09 PM
shamza's Avatar
Default How to open the boot S320 with manual key if battery is dead?
I have recently had a problem since didn't start the car (s320 w220) for a week. Did try to open it using manual key last time and used jumper.
The next two days battery dead again, this time can't open the boot. Even the key can't be turn to position 1.
Any suggestion. Please help.
Thanks.
Old May 2, 2008 | 04:36 PM
chassis221's Avatar
Default RE: How to open the boot S320 with manual key if battery is dead?
might have to turn to the left and push the button in.
Old May 6, 2008 | 01:22 AM
snanceki's Avatar
Chassis221 is correct.
Key is sufficiently large that it is not easy to turn the key and press the button in.... but it is mechanical and does not rely on the electrical assistance.
Putt the key in at 180degs to where you have it at present. This makes turning easier.
Stuart
Old May 6, 2008 | 02:29 AM
sleepwalker's Avatar
from under the hood, there is a battery terminal there for jumper.
do it from there. (remove the plastic cover with + )
Old May 6, 2008 | 09:12 PM
will3hawks's Avatar
Change the damn battery!!!!!
Old May 7, 2008 | 02:01 AM
snanceki's Avatar
IF we are talking w220 you just use the manual key and press the button. PERIOD.
Stuart
kk2
May 15, 2015 02:49 AM
kk2
Jul 3, 2014 05:00 AM
krisb60
May 26, 2011 03:13 PM
potterg
Jun 24, 2009 07:58 AM
fitzman
Sep 12, 2007 08:34 AM
