Check Engine Light - Fuel Trim Malfunction
Old Jul 14, 2007 | 07:01 AM
harryco's Avatar
Default Check Engine Light - Fuel Trim Malfunction
Hello All! My check engine light is on most of the time and a test indicated: 'Fuel Trim Malfunction Code P0170'. Can anyone tell me which sensor this one is? Thanks!
Old Jul 14, 2007 | 12:27 PM
052453a's Avatar
Default RE: Check Engine Light - Fuel Trim Malfunction
First thing to do is clean the MAF, and reset the lamp. If that fails and the lamp goes on again,you probably will have to replace the MAF. Shop around on Ebay. I had the same problem, and found a newBosh unit for $139. It fixed the problem.
Old Jul 15, 2007 | 03:32 AM
bazzle's Avatar
ONLY fit an exact Bosch or MB MAf or insert.not a clone[:@]
Bazzle
Old Jul 15, 2007 | 09:57 PM
harryco's Avatar
I'm sorry, but, what is the MAF? And where is it?
Thanks!
Old Jul 16, 2007 | 02:43 AM
P0179. Fuel Trim Bank 1.
Likely MAF. Mass Air Flow meter. Usually gives problems at 70k miles+
4 or V6/V8 engine?
Read previous posts (numerous t6hreads present). This is an extremely common MB problem.
Stuart.
Old Jan 9, 2008 | 07:17 PM
djnevoc's Avatar
Where did you find you MAF or Air Mass Meter? All the ones I find are $249
Old Jan 10, 2008 | 12:18 AM
livefreeordie's Avatar
MAF pix for a LHD, don't buy ebay junk!!!!
[IMG]local://upfiles/28125/13344C71088F481080A65F2EC2927472.jpg[/IMG]
Old Jan 10, 2008 | 12:34 AM
As Bazzle states. Only buy from MB unless you like living dangerously.
Cheaper "alternatives" do exist BUT...
Some people have had good experience (saved a few dollars) others have had bad experience... on going (different but related) problems.
I recommend using genuine parts but DIY. 5 min job. No special tools, coding, etc etc. just read this forum for details of how to remove air cleaner (subject to model) etc.
Stuart
Josh L
Nov 15, 2010 04:31 PM
paul0120
May 30, 2008 10:10 PM
webberkyle
Oct 16, 2007 09:53 PM
webberkyle
Oct 15, 2007 11:58 AM
benzowner
Jun 5, 2007 11:52 AM
