99 ml 350 low range when start car
Old Jun 22, 2007 | 09:23 AM
tim66's Avatar
Default 99 ml 350 low range when start car
ML 350 139,000 miles, when I start vehicle the low range light flashes, I'm not sure if it is going into low or not, runs fine, at cruising speed tach is about 25, anybody have any thoughts or suggestions. Does anybody know location of the brain box for tranny?
Old Jun 22, 2007 | 09:31 AM
tim66's Avatar
Default RE: 99 ml 320 low range when start car
ML 320, sorry been a long day.
Old Jun 22, 2007 | 10:55 AM
K1MOTORSPORT's Avatar
1. Start the car
2. Put gear in neutral
3. Press 'Low Range'
4. Press 'Low Range'
5. Turn off the car
6. Start the car and you will not see 'Low Range' light flashing
Old Aug 5, 2010 | 08:48 AM
wilde4art's Avatar
Default Low range light
I'm having the same problem on my 98. I tried the remedy but no luck. I have never had the need to use the low range. Should I be concerned about bigger transmission problem?
xxdanielxx
Nov 18, 2007 11:32 AM
godtammitt
Nov 25, 2006 07:47 PM
tonyb15re
Nov 21, 2006 12:08 AM
raz_1
Oct 22, 2006 04:47 AM
