What's the problem with 245/45-17 tyres on a pre 1998 SL500? SL500 Tyre size
Old Apr 13, 2004 | 02:07 PM
canzona's Avatar
Default What's the problem with 245/45-17 tyres on a pre 1998 SL500? SL500 Tyre size
What's the problem with 245/45-17 tyres on a pre 1998 SL500? The MB wheel cataolgue suggests some modification may be required.
Old Apr 13, 2004 | 10:43 PM
Lugnut's Avatar
Default RE: What's the problem with 245/45-17 tyres on a pre 1998 SL500? SL500 Tyre size
Front or back? Seems to me like those should fit. Maybe there's some unique quirk on MB wheels? I was going to put some 295-35 or 30 (I think) tires on the rear of mine, before I decided I was broke. My fronts are 245-45 now and they were going to be wider also.
Old Apr 14, 2004 | 11:20 AM
canzona's Avatar
Thanks for your comments. It was the front I was worried about although I wanted a simple life with the same size all-round. The catalogue states that 235/45 is OK but that makes the wheel over a centimeter smaller which would have a slight affect on speedometer readings and gearing etc. Taking that your 600 setup is the same as my 500, 245/45 should be OK. I did wonder whether the steering lock stops may need adjusting. Is your offset 35?
Old Apr 14, 2004 | 03:10 PM
Lugnut's Avatar
I don't know what the offset is. These aren't the original tires and wheels. The car came with 16" and has 17" now.
Old Oct 8, 2004 | 05:40 PM
fwillie's Avatar
Just as a point of reference. Go to the Tirerack web site and see what combination they would recommend. I brought 17in wheels with Micheline tires all balanced and ready to mount. They had a nice AMG style wheel that looked like Benz OEM. If you change wheels, you will most likely have to buy new lug nuts as well.
Old Nov 2, 2008 | 02:28 PM
4ws f 7's Avatar
I have them on my 96, no problem!
lola928
Aug 23, 2008 06:21 PM
Xacting
Oct 18, 2006 12:42 PM
lethalindustry
Sep 11, 2006 01:18 PM
Mercv8
Sep 8, 2006 10:42 PM
C280 V6 (UK)
Jan 17, 2004 09:11 PM
