w202 fuel tank sender problem
Old Oct 18, 2006 | 12:17 PM
GERMAN MAD's Avatar
Default w202 fuel tank sender problem
Hi everyone
i have a w202 with a constant prolem ie it cuts out , turns out that the scavange pump that keeps the level right in the tank is not functioning correctly , has anyone got a diagram it is a w202 193 estate car , senders are under tank , does anyone know of any common problems , sensors seem to work . We fed tha car from seperate tank as it was empty in car tank , we allowed fuel to go back on the return into other side of car tank. This meant we had two gallons of fuel go up return side , however none coming out of other side of car tank i.e side of fuel filler . Hope you can understand this but also help me with diagram.
Many thanks in anticipation .
Old Jul 12, 2009 | 05:56 PM
mercfancy's Avatar
Banned
Unhappy Fuel starvation on one side of the petrol tank
hi there,
i have the same problem and been strugling for almost a month now, still cannot solve the problem?
did you menaged to find the cause for no fuel return??
thanks
Dobschcan
Jun 4, 2011 07:30 AM
bbmlpoole
Nov 28, 2008 01:42 AM
stridemiester
Mar 24, 2008 11:40 AM
rossl
Aug 3, 2006 08:42 PM
rossl
Jan 9, 2005 10:56 PM
