SLK 230 PSE pump
Old Dec 11, 2007 | 09:53 AM
musksteer's Avatar
Default RE: SLK 230 PSE pump - part #
the right latest part number is: A170 800 08 48.
price is 322.50 euro
Where did you get a quote of 322.50 euro?
I've been quoted euro 535 + tax from a local MB dealer.
Thanks,
M
Old Mar 26, 2008 | 04:29 PM
slickslk's Avatar
The price i was quoted recently from MBZ dealer was U.S. $510 (part only!) - waaaaay too much for what is essentially a design flaw (water coming thru via wires??) Anyway, finding this as a replacement part is pretty impossible outside MBZ, however contact the salvage yards in the area and ask if they have an SLK...the way this part is designed it is pretty interchangeable through a number of the model years. Also, the codes are already in, so it's pretty much a plug and play situation (not hard to remove, not hard to re-install)...hope this helps all others to avoid some of the frustration I went thru to fix my PSE
Old Mar 28, 2008 | 07:26 AM
bazzle's Avatar
http://www.benzworld.org/forums/r170...fit-check.html
Bazzle
Old Mar 30, 2008 | 04:45 AM
slickslk's Avatar
Thx Bazzle for the link and the instructions - actually, I read through it while trying to figure out what/where the hell the PSE was located - and so got the courage to try to do it myself!
Updating, I got the part installed - was able to put the unit back in upside down, which requires simply turning the unit on the horizontal axis (front becomes back) - this allows the wires to stretch so you can mount it upside down. Did spray WD-40 in the connectors but not the conformal coating on the PCB and...voila! It works
Old Mar 30, 2008 | 04:49 AM
slickslk's Avatar
Uh - with one *minor* annoyance - everytime I go to turn on the car, as soon as the key hits position '2' the car alarm goes off for exactly one "honk" of the horn - right now, i'm too pleased with the $500 i saved to be overly concerned...but it would be nice to figure out how to fix it [>:]
Old Oct 8, 2008 | 09:31 AM
  #16
jag man's Avatar
my pump # 1708000488 used pump # A1708050019 will this work My car is a 2000SLK the one I can get a pump from is a 2002SLK
Old Oct 26, 2008 | 08:01 AM
  #17
jag man's Avatar
bought a new pump from the dealer for $408.00 ( that was wholsale price) everything works great except the doors do not automatically lock when the car is put in gear or starts to move....anyone got any ideas?
Old Jun 24, 2009 | 04:46 PM
  #18
gale's Avatar
Hi - I noticed your post and hope you don't mind my asking. We need a new water pump and wondered how to make sure we've got the right part. It's a 1998 230SLK Kompressor. I noticed one on eBay, and it says it will fit the 1998, but I don't want to end up with a part that won't work. I saw your post and wondered if the VIN is necessary? Thank you - Gale
Old Jun 24, 2009 | 06:15 PM
  #19
livefreeordie's Avatar
You don't need a vin, your best bet is to call the dealer for the part number unless you have an account (free) with EPC (https://epc.startekinfo.com/epc/welcome.jsp) then you can look up the part yourself.
neilbaud
Mar 30, 2008 12:56 AM
ballast
Mar 13, 2007 03:19 PM
mwfcpa
Nov 1, 2005 09:55 PM
99CL600
Jul 21, 2005 06:30 PM
westscot
Feb 4, 2004 10:00 PM
