97 S420 Wont Start.....
Old Mar 23, 2010 | 06:39 PM
AL-Tuwaijri's Avatar
cause when u turn off the car the fan stop and the temp increasing so u should leave it for 10 minutes at least
Old Mar 25, 2010 | 08:04 PM
dimka18's Avatar
Originally Posted by soaring1
I recently changed the Throttle Body on a 1994 Mercedes S320 afterwards when I crank the vehicle up,The Idle is very high about 2000 rpm and the Asr light is on at all times.I remembered after installing the throttle body that i forgot to put the gasket on the bottom, would this cause high idling or does it sounds like something else.
Hey, i have the same problem in my 95 s420, i changed the throttle body and when i started the car it worked fine for about 40 sec then it just cut out ASR light come on, and half the throttle down does not work. Let me know if u fixed this problem cuz i still cant figure out what wrong with mine.
Old Mar 26, 2010 | 04:58 PM
NAZ's Avatar
NAZ
Ok leave the ignition swithed on for 10 min than star the car see wat happens if the idling reduces than u=its been set if not this will need star diag to reset all adptations.....
Old Mar 27, 2010 | 02:31 AM
dimka18's Avatar
hey naz, i already tried that nothing happens, and also i took my car to my local mechanic he said that the E-GAS computer is no good, and i cant find one to fit my numbers anywhere.
Old Apr 18, 2010 | 01:22 PM
MrDiego's Avatar
Hey 97...What was the problem?
Old Aug 22, 2010 | 10:42 AM
  #16
angelomorales1's Avatar
Default removal ignition switch for 98 s320
ive ordered the switch but not sure how to remove the old one do i need any special tools to remove tumbler
daddyz7
Nov 17, 2019 04:07 PM
g-rome
Oct 6, 2012 03:10 PM
jvision09
Apr 18, 2011 07:59 PM
alex95060
Jan 6, 2008 06:04 PM
nellybee
Mar 12, 2005 01:14 PM
