Brake Wear Warning Light
Old 07-07-2005, 11:03 AM
merlynp's Avatar
Default Brake Wear Warning Light
I have a 2001 S430, with 60K miles. It has been perfect!
The brake wear warning light just came on. I know it is for the front brakes. I intend to do my own brake work. How much time/mileage do I have, before I begin to do damage. I will also be replacing the rotors. Any suggestions for where to go to get tips on making this job easier? All my brake work has been on GM cars.
Thanks for your help!
Old 07-07-2005, 12:17 PM
sleepwalker's Avatar
Default RE: Brake Wear Warning Light
you still have about 4mm left. quite safe for the next 200 miles.
replacing the rotor is just an additional job of removing the two screws of brake caliper.
replace the brake pad sensor too because the circuit is already broken.
Old 07-07-2005, 02:20 PM
C280 wizard's Avatar
Sleewalker is correct, I wouldn't wait too long.
Old 07-08-2005, 05:35 AM
SL600_Cruzin's Avatar
Exactly as the two gentlemen above me stated..... don't wait too long ....
If you plan on replacing the rotors as well, then it's not such an urgency to replace the pads, although I recommend that you keep a good eye on the thickness of the pads so you can still stop, which can be helpfull at times.
60K miles is pretty good for front brake pad life, mine usually burn up in about a third of that time. My ML weighs probably twice is much so that's probably the difference. Also, I only use factory pads ... dust flys everywhere!
If you've done pads on a GM you shouldn't have any trouble doing your benz.
If you need any torque specs etc.... let us know.
Cheers,
TJ
Old 07-08-2005, 01:36 PM
merlynp's Avatar
Cruzin, thank you so much for the advice. Yes, please let me know of any torque specs that are required for the bolts. Thanks!
nbrock_85
11-30-2011 07:15 PM
hrl3972
08-02-2009 11:14 AM
LTJR1969
01-12-2009 01:19 PM
nufc
09-05-2007 03:28 PM
stevey88
03-18-2007 05:19 PM
Quick Reply: Brake Wear Warning Light
