Valve Cover Gasket Question
Old 04-15-2008, 08:44 AM
plw's Avatar
plw
plw is offline
Default Valve Cover Gasket Question
I have a '97 E420 with 130,000 miles and was told the valve cover gaskets should be replaced. Cost estimate seemed high to me - $550 from an independent shop I use. Always thought that was a pretty simple procedure, although I have never done it on a MB. Anything unusual, diificult, or need to watch out for on this model? Suggestions?
Old 04-15-2008, 09:27 AM
ohlord's Avatar
Banned
Default RE: Valve Cover Gasket Question
Someone is trying to rip ypi off.
http://www.mercedesshop.com/Wikka/M119OilGuides
Undo the covers install new gaskets and while you are in there check the oil guides.
Several of our members on benzworld.org and mbworld.org have had the noisy lifter tap and solved it with this diy.If all you need of the pictoroal diy is the valve cover info,Get it done.
They also list the washers and grommets
http://www.autohausaz.com/search/pro...20Gasket%20Set
if you would like to a member named citruspilot did his guides and would be glad I am sure to give you more info if you pm him on mbworld.org w210 section or benzworld.org w210 section.
ohlord
http://www.mbworld.org/forums/member.php?u=43027
Old 04-16-2008, 12:35 PM
plw's Avatar
plw
plw is offline
Thanks. Looks prety straightforward. I called a MB dealer to double check and they said $680 with 4.2 hours of labor!
az300e
04-10-2018 02:06 PM
sal911
09-19-2010 11:05 AM
jallen78
05-08-2009 07:28 PM
highsiera
07-13-2007 09:40 PM
bchengwa
04-09-2007 12:45 PM
Quick Reply: Valve Cover Gasket Question
