Mercedes CL Class Mercedes CL500 and Mercedes CL600 Coupes.
How to remove front turn lamp bulb
Old Mar 12, 2007 | 04:14 PM
02cl55's Avatar
Default How to remove front turn lamp bulb
New owner having trouble removing front rt turn bulb? How does the lamp come out of the housing?
Thanks for the help.
Old Mar 12, 2007 | 05:27 PM
02cl55's Avatar
Default RE: How to remove front turn lamp bulb
Nevermind, that was easier than I had thought. New question: Rt turn bulb, even when replaced will not work. Causes malfunction message on dash screen. Any suggestions? I have cleaned the contacts, replaced the bulb.
Old Apr 25, 2007 | 01:35 PM
JCoop's Avatar
Not as easy as you think; it's a fragile assembly and easily broken when one forces the twist-lock mechanism. It displaces the contacts if you're not careful. It may look and feel OK, but the side contacts inside the housing is probably f****d up. You may be able to bend it gently but otherwise, a new housing may be the answer.
rradlein
Feb 6, 2011 10:22 AM
andrew9147
Nov 11, 2010 05:24 PM
angiebee1109
Jun 16, 2009 07:14 PM
Mr. Benzo
May 8, 2007 09:38 PM
02cl55
Mar 29, 2007 04:04 PM
