Wheels/Tires Need custom rims? Have a tire question? Come in and let's talk.
190E wheels size help?
Old Feb 26, 2007 | 04:05 AM
sean 90 190E's Avatar
Default 190E wheels size help?
I just got a 1990 190E 2.6 and I don't know what size wheels/tires can fit on there. I'd like a set of 17 or 18" rims, but how wide of tires can I fit?
Old Feb 26, 2007 | 02:31 PM
AMGMercedes's Avatar
Default RE: 190E wheels size help?
Let's put it this way, my 18 inch rims have rear tires that are 9.5'sand the front tires are 8.5's. Is that big enough?
Old Feb 26, 2007 | 11:49 PM
ORIGINAL: AMGMercedes
That's definitely big enough.So thats at least a 225 in the front and 255 in the rear? Will there be any rubbing problems?
Old Feb 28, 2007 | 02:25 AM
With the right tires and stock suspension, no there shouldn't be rub. If you plan to drop your car or not go with low profiles, then yes.
Old Mar 1, 2007 | 10:07 PM
pnp01's Avatar
ON a 190E you need to be careful of wheel & tire sizes, in 17" you need a 7.5 or 8.0 width max. with a minimum of a 35mm offset. 38-40 is better. Tire size should be 215/45-17, some guys run 245/40-17 in the rear, but most times it rubs and you need to modify the fenders. Another way to go is 215/40-17 front and 245/35-17 rear. these are very hard to find, and very easy to damage due to the low profile.
In 18" you will need the same width and offsets, but your tire size needs to be 225/35-18.
If you are in the N.Y. area,call Parts & Polish @ 516-466-3553 ask for Jonathan, tell him Dennis sent you!
Good Luck!
Old Apr 15, 2017 | 08:13 PM
Cameron Chavis's Avatar
Default 190e 2.6 rim problem
Good Luck!
hey how you doing I just bought some rims for my 190e that were from a SL merc that are the same size and I think same bolt pattern but when I tried to put the lug nuts in they wouldn't fit I was wondering if I need spacer or just need new rims altogether
Any ideas
Old Apr 18, 2017 | 12:51 PM
PelicanParts.com's Avatar
If anyone has any questions on wheel fitment and/or spacing, take a look at the link below. It's a very helpful, easy to understand guide.
Wheel Fitment and Spacing Guide - Pelican Parts
-Dmitry
Old May 12, 2017 | 05:38 AM
Marlon47's Avatar
17" is good enough
Old Oct 15, 2019 | 12:53 PM
  #9
Ron Suriano's Avatar
Alright, professionals, I'm relying on you! Will 225/60R17 tires on 17x17.5" wheels fit my 1991 190E 2.6? Thanks in advance for your assistance. Best, Ron
Old Dec 4, 2023 | 09:49 AM
  #10
Nuhify's Avatar
Question 190e 2.6 Rims AMG
I have a 2.6 and O.Z Aero's (17x10 rear and 17x9 front), will these fit without wider fenderskirts from a 2.3 16V, EVO1, EVO 2? Best regards, Noah
mitch190
May 21, 2009 09:39 AM
gcas
Aug 30, 2007 10:51 PM
danstrand
May 5, 2007 02:03 PM
nick kate
Apr 8, 2007 03:04 AM
mgw_300e
Feb 20, 2006 09:55 AM
