Brake Warning Lamp Lit? Replacement Brake Pads In Stock! By Pelican Parts
Replacing your brake pads is one of the easiest jobs to perform on your Mercedes. In general, you should inspect your brake pads about every 25,000 miles, and replace them if the material lining of the pad is worn down enough to trigger the pad replacement sensor or there is less than a quarter inch of material on the pad.
With minimal tools and less than two hours of time, you can have those worn pads out and new pads installed!
We offer pads for your Mercedes-Benz by Genuine Mercedes, Jurid, Textar, Akebono, ATE, Bosch and more! Enter your vehicle information here then shop for brake pads!
Let us know what questions you have!
PelicanParts.com
08-27-2013 12:27 PM
PelicanParts.com
06-05-2013 12:46 PM
PelicanParts.com
05-15-2013 12:40 PM
PelicanParts.com
05-08-2013 11:50 AM
PelicanParts.com
05-02-2013 06:57 PM
