Other Post discussion on all other models not listed above here.
Gas gauge problem on my 190E
Old Nov 6, 2007 | 03:10 PM
g1golo's Avatar
Default Gas gauge problem on my 190E
Just the other day my Gas gauge, Temp gauge, and Oil gauge stopped working. However the Economy gauge located in the same cluster is still working. The Speedometer and RPM gauge on the other clusters still work. Can I get some help.
Old Nov 8, 2007 | 06:32 PM
slk230red's Avatar
Default RE: Gas gauge problem on my 190E
The only time the fuel guage failed to work on my '93 190E 2.3 was when the brake light fuse blew. I noticed it while I was driving so I stopped at a parking lot and looked things over. I could see that the 3rd brake light wasn't working, so I had my wife check the other brake lights and they were also not working. Sure enough, I pulled the cover off of the fuse panel and the brake light fuse was blown. Fortunately, there was a spare fuse in the holder...replaced it and no problems since.
Old Nov 8, 2007 | 07:14 PM
g1golo's Avatar
I have a 1990 2.6 and the brake lights work. There are no blown fuses. The oil gauge and temp gauge also are not working. Thanks anyway.
Old Nov 9, 2007 | 10:22 AM
g1golo's Avatar
Hey, My brake light just went outbut the fuse did not trip, but I replaced it anyway and it fixed everything. Thanks!!
Old Nov 10, 2007 | 04:55 PM
slk230red's Avatar
ORIGINAL: g1golo
Glad it worked out for you g1golo. Sometimes the fuses don't seat very well and the result is an open/loose circuit. The next time I remove my battery, I'm going to remove every fuse, clean the contacts and re-install.
Dave
Old Sep 7, 2008 | 08:03 PM
toptoad713's Avatar
thanks guys, this has been a problem for me for about a year, it was as mentioned the brake fuse. I did not know that the brake lights weren't working. It was fuse number 9. Hurray it works!!!
Old Jan 11, 2018 | 10:24 AM
dowdis's Avatar
Default Thanks!
I created an account on this forum just to thank you guys for the tips. My '93 190E had no working brake lights/gas gauge when i woke up this morning. I reset fuse 9 into place and all is functioning again.
More than 10 years later and this post is still extremely helpful!
Old Jan 11, 2018 | 10:25 AM
dowdis's Avatar
Default Thanks!
Old May 26, 2019 | 11:21 AM
  #9
Marghie's Avatar
Red face Thanks yet again.
My daughter's gas/oil/temp gauge was out. I had visually checked all the fuses, and none looked blown. I was about to schedule at the garage when I saw this post. Didn't realize she had driven with no brake lights either. Sure enough, the fuse was blown, but the tension from the clip was holding the filament together. Thanks so much, you just saved me an expensive trip to the mechanic, and very likely an accident.
Old Nov 13, 2024 | 11:03 AM
  #10
papabear244's Avatar
I would also like to extend my gratitude to the fellow members that contributed to this thread. In my case it was fuel/temp/oil gauge and brake lights not working. Replaced fuse 9 and everything worked again. I also took the opportunity to replace fuse 10 even though it was not bad. But I have noticed the windshield wiper would sometimes not start.
EDIT: I suspected the brake lights were not working because I noticed cars behind me would stop too close to me, and sometimes they would honk at me. I thought that's weird. When I got home I confirmed they were not showing.
Bergermiester
Apr 6, 2016 09:54 PM
JasonL12
Jun 4, 2012 08:15 PM
benz24
Aug 30, 2006 12:08 AM
cunnindj
Sep 20, 2005 12:08 PM
pseverin
Sep 29, 2004 07:32 PM
