Other Post discussion on all other models not listed above here.
1985 300CDT transmission problem
Old Mar 16, 2010 | 08:39 AM
rjr's Avatar
rjr
Default 1985 300CDT transmission problem
1985 Mercedes CDT when put in drive will not start out in low gear. It will not downshift when accelerator is pressed to floor. Reverse works fine. Car will drive in high gear. Transmission can manually be shifted thru lower gears. What might be the most likely problem.
Old Apr 28, 2010 | 11:00 PM
cycleboy's Avatar
To be honest, I don't know. Normally failure to get moving would be a bad B2 piston, but if the transmission will go when you put it through the lower gears manually, I am stumped. Maybe I am just not properly understanding you.
Imok
Dec 1, 2010 02:51 PM
Hogie
Dec 7, 2008 01:00 PM
gdsmithfl
Mar 28, 2008 01:08 PM
cycleboy
Mar 6, 2008 07:08 PM
jccnbenitez
Jan 5, 2008 12:02 AM
