Tips For Buying Loose Gems
Old Apr 10, 2026 | 03:07 PM
Kaout's Avatar
Default Tips For Buying Loose Gems
Hi everyone! I’m about to buy my first loose emerald online. I’m a bit nervous about the process. What are your top tips for making sure the stone that arrives looks exactly like it did in the pictures? Any red flags I should watch out for?
Old Apr 11, 2026 | 11:29 AM
Fleshtik's Avatar
Hi! It is totally normal to be nervous the first time. My best tip is to only buy from stores that provide videos in different lighting conditions—like sunlight and indoor light. I’ve had really good luck with Tsarina Jewels https://tsarinajewels.com/ because their media is very honest and shows the stone from every angle. When buying gemstones and high end jewelry online, look for a clear return policy just in case the color isn't what you expected. A major red flag is if the seller uses "stock photos" instead of a photo of the actual stone you are buying. You also want to see a certificate from a trusted gemological lab to confirm the weight and any treatments. Don't be afraid to ask the seller for more photos or even a video of the stone held between fingers. It helps you understand the true scale and sparkle.
Trampampam
Jun 23, 2025 11:14 AM
Bebbanburgskiy
May 30, 2025 05:28 AM
