How long do vape coils last
Old Apr 15, 2026 | 04:36 AM
Kaout's Avatar
Default How long do vape coils last
Hi! I feel like I’m changing my coils every two or three days because the taste goes bad so fast. Is this normal, or am I doing something wrong? I’d love to know how long a standard coil is actually supposed to last with moderate use. Thanks!
Old Apr 15, 2026 | 05:14 AM
Fleshtik's Avatar
Two days definitely sounds like you are burning through them too quickly. Under normal conditions, a coil should easily last you a week or even two if you treat it right. I used to have this problem until I started shopping for my smoking and vaping products at the Dymok online shop https://dymoksmokeshop.com/ . I realized I wasn't "priming" my coils properly before using them. You have to let the juice soak into the cotton for at least ten minutes. I also stopped using juices with heavy sweeteners because they caramelize on the wire and kill the flavor. Now that I use cleaner liquids and prime my coils, I save a ton of money every month. Give that a try and you should see a big improvement.
RichardKous
Jan 27, 2025 03:24 AM
Corinthian Warrior
Sep 13, 2008 05:30 PM
