AM static noisewhen brakes applied on 98 ML320
Old Jan 17, 2008 | 01:28 PM
firstfeather's Avatar
Default AM static noisewhen brakes applied on 98 ML320
HELP!!!!!!!!
On my 1998 ML320 when the brakes are applied I get bad static on my AM radio stations.
It seems to be worse as the brakes are initally applied and as they are being let off. It happens at all speeds and conditions.[X(]
I am not noticing any braking problems.
Initally it was only the staic but now at times I also get a idiot light on the panel that flashes sporatically. It is the "brake pads worn down light".[&o]
The static started about 2 or 3 weeks ago and the light about one week ago.[X(]
Question is: Could the staic be caused by the brake pads or is there something elso???????
I would apreciate any help.
[/align]
Old Jan 17, 2008 | 07:05 PM
chassis221's Avatar
Default RE: AM static noisewhen brakes applied on 98 ML320
it is caused by the brake pad wear sensor rubbing against the rotor. replace the brake pads, or remove the wear sensor, that should cure the problem of the static.
Old Jan 18, 2008 | 03:32 AM
M.Gomes's Avatar
try to remove the brake sensor wear, or make shure if the wear are well conected. replace the pads. make shure they are genuine.
Old Jan 20, 2008 | 09:15 AM
Altraide's Avatar
I'm a new member. Any blahs?
Old Jan 21, 2008 | 01:11 PM
Anyone know any good web sites that detail the brake replacement process and any special tools needed???
Also any good web sites to purchase pads???
[/align]
Old Jan 21, 2008 | 06:40 PM
97dmsrS420's Avatar
Just look upon the board here, and you'll find many sponsors that deal with MB Performance and Replacement Parts. The other option is Google. But welcome to the forum.
Old Mar 25, 2008 | 04:11 PM
Repaced the front brake pads, was actually quite easy to do. This solved the problem with the static on the radio. Be sure that your new pads come iwth the steel guides.
slodown
Jun 26, 2015 07:01 PM
Rusty Westgate
May 17, 2015 01:17 AM
firstfeather
Jun 22, 2010 06:24 AM
tropics
Mar 30, 2008 08:36 PM
fraguada1
Mar 1, 2006 11:59 PM
