'88 420 SEL repair hood insulation
Greetings:
I have a (classic) well-cared for M/B; model referenced above. Presently, the hood insulation has detached from the interior of the hood; approximately three-fourths of the insulation hangs down when hood is in upright position. I have been advised to a) remove the insulation completely; do not replace item, b) use clear silicon caulk to re-attach the insulation, and c) ignore the situation. I want to re-attach the insulation to the hood. This car is a beauty and I have complete respect for the machine. I want to maintain the integrity of the automobile as best I can. The insulation appears to be in good condition. Please advise as to the process and materials you consider the best to repair the hood insulation to resemble (at best) its original condition.
Your time and commitment to M/B auto owners is greatly appreciated.
Regards,
Susan
Regards,
Susan
do not remove it.
not only that it protects the paint from high temperature, but also reduce the noise and vibration.
it doesn't look good without the insulator also, and reduce the value.
The advise of Sleep walker is sound and logical. What you can do is to clean the area where the insulation is and try to remove all the deteriorating insulation foam under the hood. Buy a tube or so of liquid nail. Apply the liquid nail on the bare under hood and leave it until tacky , then attach the insulation, apply presure and I guess thats about it.
My suggestion if the material is deterriorating. Contact Performance Products or another good supplier and purchase a replacement. I did so on a 1996 SL. I put and old sheet over the engine and peeled off the old foam. Much of it in little pieces. Then used a plastic putty knifr to get the remainder off. I ordered the new mat and a can of spray adhesive that performance recommends, carefully sprayed both the foam and the undeside (particularly neat on the edges) of the bonnet but not too heavy. With another pair of hands installed the new one. We both wore nitrile gloves to keep the glue off. A few areas needed extra adhesive, just carefully pull down the edge and shoot it in. Looks 100% better and if it lasts another 16 years, I'll be more than happy!!
Mercedes Benz SL-class is now introducing the new2013
Mercedes Benz SL550 which is going to hit the market in the mid of 2012. The latest 2013 Mercedes Benz SL class will offer you more comfort and athletic characteristics. This is going to be the most stylish and luxurious version of the SL class of cars
