Where does this wire go?
Old Sep 14, 2006 | 05:31 PM
SLiK32's Avatar
Default Where does this wire go?
When I went to replace my driving lights, I found this hanging on the drivers side. I was told it is the temperature sensor - I assume for the dash temp display. Does it get mounted anywhere or it just flops around in there? It doesn't seem like a good idea to leave it hanging like it is.
Any clue where it goes? It's an '02 SLK32.
http://home.ptd.net/~kevkem/wire2.jpg
Thanks!
[IMG]local://upfiles/14307/A0A416CFE5AF4446836A7262F36110AF.jpg[/IMG]
Old Sep 14, 2006 | 07:14 PM
DesignoSLK's Avatar
Default RE: Where does this wire go?
Hey SLiK32! Welcome to the forum. I found mine popped out a couple of times too. It clips into a hole in the lower part of the grill below the bumper on the driver's side, but above the fog light. It's a little bit of a contortionist maneuver, but doable.
Old Sep 15, 2006 | 12:35 AM
SLiK32's Avatar
Thanks!
Hopefully tomorrow I'll have time to look for that hole.
Old Sep 15, 2006 | 06:37 AM
snanceki's Avatar
Its not a spare wire. It is the external temperature sensor.
It clips to the lower radiator grille in the space adjacent to your LH fog lamp. Its tip actually pokes through the grille to the front into the air flow.
Too difficult to describe the actual clipping arrangement. WIS doesn't have a picture of the clip which helps.
Presumably the bumper has been off at some time and the mechanic didn't locate the sensor correctly. Unlikely to come off on its own.
Stuart.
Old Sep 15, 2006 | 01:58 PM
SLiK32's Avatar
Thanks Stuart. I think I can find it now that I know better where it goes.
As for why it's hanging loose....
It isn't the only thing the dealer has screwed up on. I've been extremely unhappy with dealership service. The car has not performed the same since they had it for warranty service.
Kevin
Old Sep 15, 2006 | 02:55 PM
DesignoSLK's Avatar
SLiK32...is your avatar a picture of your car? Post pics...
Old Sep 16, 2006 | 03:23 PM
SLiK32's Avatar
The avatar is my car. I took that picture in the warehouse at work when the power went out and I was looking for something to do...then lost the fuillsize original when the PC died...
Being new here - what's the SOP on posting pics? I'll try to post some soon.
But here's one for now:
Kevin
[IMG]local://upfiles/14307/9A6A67C1A9914A16A68D7745A3A144AF.jpg[/IMG]
Old Sep 16, 2006 | 05:18 PM
snanceki's Avatar
Hi Kevin,
EXACTLY how did you manage to upload your picture.
I believe I have done everything correctly (including resize) but am unable to upload a .jpg.
What is the exact size limit please?
Thanks in anticipation.
Stuart
Old Sep 16, 2006 | 07:37 PM
  #9
SLiK32's Avatar
ORIGINAL: snanceki
Hi Kevin,
Stuart
For the avatar picture? I tried multiple times without success, from My Profile. Then one time it worked. I don't know what I was doing wrong or what I did right....I'm new to forums, preffering mailing lists instead.
(145 X 145) Max. 20KB according to the upload window.
Kevin
Old Sep 16, 2006 | 07:40 PM
  #10
SLiK32's Avatar
Thanks to you guys I was able to find the mount for the sensor. It is part of the small grill. I was trying to find it from the wheel well, through the removable cover. It was much easier after popping the driving light grill off. It wouldn't stay in place, likely needs new rubber. So I wired it in. It won't go anywhere until I say so...
