Replacing the remote side mirror switch
Old Aug 20, 2007 | 07:29 PM
custmbld's Avatar
Default Replacing the remote side mirror switch
Hello, Can you all give me some help on the method to remove and replace the remote mirror switch in my 1998 slk230 ? It looks easy enough but....
Thanks in advance
Tom
Old Aug 24, 2007 | 08:56 AM
bazzle's Avatar
Default RE: Replacing the remote side mirror switch
Remove 2 10mm nuts under carpet inside centre console.
Remove chrome trim around gear selector (pull up with finger nails)
Remove trim from around gear lever arae (lever up to rear between where chrome trim was)
Remove 2 small phillips screws.
Warm up handrake handle and slide off forwards (tight)
Carefully remove centre console
Switches held in with small screws underneath.
Bazzle
Old Aug 25, 2007 | 10:55 AM
custmbld's Avatar
Bazzle
Sounds self do-able
Thank you.
I will take a run at it.
Tom
cliff
Nov 3, 2008 06:38 PM
MrsP
Aug 10, 2008 07:20 AM
montero1
Sep 17, 2007 05:38 PM
Mywifescar
Jun 10, 2006 12:44 PM
Mywifescar
Jun 10, 2006 12:42 PM
