remote control system malfunction
Old Dec 16, 2014 | 12:15 PM
anniefred29's Avatar
Default remote control system malfunction
Hi! Mine is an slk230k 1999 model. Yesterday my remote control malfunctioned and now not able to use the locking system other than manually. Need to chanfe the control unit. Any idea of the cost? Pls help.
Old Dec 18, 2014 | 02:11 PM
brookings's Avatar
is the key transmitter or battery ok? check prices on 170 820 11 26 or 170 820 18 26 DAS module. my 98 uses the 11 26. I found it new at www.qenuinemercedesparts.com for $200. it's located behind the instrument cluster above the fuel and temperature guage. might check on compatibility though. I think it may need to be programmed to the key transmitter and will require lock and chassis numbers. my alldata subscription isn't clear on the process, might ask the local Merc dealer's service dept..
Old Dec 20, 2014 | 09:18 AM
Hi! Thank you very much for the revert. The problem is not with the key or the battery. It's the control unit that is located in the right side bottom of the cars boot. Looks like water has somehow entered and the circuit has blown causing the unit to shut down. Have asked the local mercedes dealer for costs but still awaiting an estimate.
Old Dec 22, 2014 | 03:50 AM
brookings's Avatar
it's the 170 800 08 28 PSE pump/control module you can check prices by part #. Auto Parts at AutohausAZ - OEM Auto Parts - Discount Replacement Parts, Resources and Car Care Tips under "electrical and vacuum" they have them new for under $600. it shouldn't take over a 1/2 hour to replace. you can replace yourself easily. Take out the trunk floor cover. remove tire according to owners manual, open foam box to the lower right side of trunk behind jack tools/hardware and remove pump.
Old Dec 23, 2014 | 10:17 PM
Thank you very much for the help. I shall order the part and have the installation done at home.
thomasmaio
Mar 13, 2015 01:49 AM
paul0120
May 30, 2008 10:10 PM
fpugliano
Jun 20, 2006 12:52 AM
Sport99
Apr 27, 2006 01:46 AM
L1MASTERTECH
Mar 26, 2006 11:44 PM
