Keyless Remote Malfunction
Old Apr 20, 2006 | 07:06 PM
Sport99's Avatar
Default Keyless Remote Malfunction
I recently replaced the batteries (bought from the dealer) in my keyless remote and now I am having problems getting it to work. Yes, the batteries are in correctly!! I have a 99 C280 Sport. When I press the unlock button the parking lights flash and the interior dome light turns on but the car remains locked. When I press the trunk and lock buttons the red light blinks but nothin happens. Does anyone have any idea what this means? Do I have to order a new keyless remote? I was told that maybe the car does not register the infrared signal from the remote to the car? HELP... PLEASE!!!!!
Old Apr 23, 2006 | 05:53 PM
Russell's Avatar
Default RE: Keyless Remote Malfunction
if your cars light flash when you press your remote, the car is recieving the signal, your remote is fine, sounds like your central locking pump is not working. if you press the lock/unlock button on your centre console, does your central locking work? if not check your fuses. or your central locking pump has burn't out (common fault)
Old Apr 27, 2006 | 01:46 AM
Sport99's Avatar
Thanks for your response!! The center console switches nor the central locking switch are working. Where is the central locking pump located? I have tried to check the fuses but I cannot access the fuses in the trunk. With the console switches, that operate the windows, mirrors and trunk, not working I have to use the mechanical key to lock the doors. BUT... the mechanical key will not unlock the trunk. Is there any other way to access the trunk? possibly taking out the back seat? I have decided to take my car in to have it serviced, do you think this will be costly to repair? Any feedback would be appreciated.
kam9090
Dec 14, 2007 10:08 PM
ACLineman
Jun 23, 2007 05:41 PM
sbeemish
May 7, 2007 04:27 AM
nmantiquarian
Aug 9, 2006 02:27 AM
92300se
Jul 21, 2005 03:45 PM
