Newbie help! 98 SLK230 loss of power
Hi all, I've recently bought a 1998 SLK230k, (auto)and it seems to be down on power. With the foot to the floor it is very sluggish. It seems to have developed a bit of a shudder when driving. I'm also in two minds as to whether the gear change is working properly too as it seems to take a while to change up. I canhear a kind of sucking noise when I accelerate too, never heard it before now. No warning lights have come on. All help will be very grateful! Cheers!
Start with basics, change fuel filter, air filter.. The noise your hearing might not be a sucking but a blowing noise, check all lines, connections for supercharger,intercooler,intake tubes, all boots and clamps...
I had to change the Mass Air Flow Sensor on mine. Sounds like very similar symptoms. Cost me $500 from the dealer. I went through plugs and wires first and that didn't work so i went to the sensor and that solved my problem.
Thyere are several threads about MAFs. I havve replaced mine x2 on my 99 SLK 230 but some of the threads suggest a good can of MAF cleaner is the place to start. As I remember, it is important to keep the electronic components free of the cleaner stuff. Look up MAFs in the forum and it should give you a lot of info.
