new to forum transmision oil level
Old May 12, 2006 | 04:03 PM
juanpablo's Avatar
Default new to forum transmision oil level
hi
i live in mexico and here the mb service is very bad so i have been learnig, the thing is last week i had to change the transmision conector becase was leeking and the i refeel the same amaunt that came out, but i dont know if it nneds more because it dosent have the mesurement thing in the refill, i have a x431 scantool but it dosent show any sensor of the level
does any one have a plan or measurments to build this tool
thanks
slk 230 2004
Old May 12, 2006 | 05:45 PM
bazzle's Avatar
Default RE: new to forum transmision oil level
Unfortunately you will need a service tool.
It is called a dipstick and is used to check level only.
It doesnt stay in tube.
Can be got from a dealer or Ebay or Online parts places.
http://search.ebay.com/search/search...ick&category0=
Bazzle
Old May 12, 2006 | 05:49 PM
juanpablo's Avatar
thanks i´ll look for it
Old Dec 26, 2007 | 10:01 PM
wonderwoman's Avatar
Hi Bazzel,
I have read your posts for a while now, and I am getting my stuff together to change my transmission fluid. Can you tell me how to make a dip stick? I looked at ebay and there are a ton on there, not sure which one I need. Also, yes I will use MB oil and stuff. One question though, for draining the differential - would there not be a plug under there on a 2001? If there is not, you are saying that I have to change this 2 times after a couple hundred miles? I sure hope not! Also, is it necessary for me to buy a torx wrench? I don't have one but my neighbor may have one. You also talked about turning the transmission in order to drain the differential. Where is that located?? I don't know all of the parts!!!! I iwll try and follow your instructions to the tee.
Thanks a bunch for your help. You are a very knowledgable on this stuff and it is greatly appreciated.
Penny
Old Dec 30, 2007 | 01:27 AM
bazzle's Avatar
From about 1998 on there is no torque convertor drain plug.
Just suck out a couple of litres evary week or so a couple of times thru dipstick filler hole.
I use a vacumn oil pump to drain my engine oil thru dipstick for the engine. Same can be used for subsequent draing of trans after initial filter change. I have a 6.5 litre one.
http://www.whitworths.com.au/main_it...AbsolutePage=4
Trans Dipstick pic below dims in centimetres.
Bazzle
[IMG]local://upfiles/5777/EE486AFB0B9F41698A1405F34982198E.jpg[/IMG]
bosnian
Mar 9, 2009 01:33 AM
juanpablo
Dec 28, 2006 06:15 PM
zafar320
Jul 8, 2005 05:01 PM
kev2
May 23, 2005 12:20 AM
CCCP
Feb 18, 2005 05:10 PM
