leaking transmission on my SLK230 1998
Old Dec 24, 2004 | 02:59 AM
bumanng's Avatar
Default leaking transmission on my SLK230 1998
I know were the leak is coming from. There is a "wire housing" on the passanger side of the transmission just above the pan near the front of the transmission. Fluid is leaking around the outside of this wire housing. I talked to the MB dealer. They said this is a common problem on this transmission. Leaks more when it is cold. They can install a new and better housing for a mere $250.00. I want to fix this myself if possible. Doea anyone know what this housing is called? Does anyone know if this problem has a TSB written on it? If there is a TSB on it does anyone have a copy of it?
firstfeather
Mar 25, 2008 04:14 PM
jons
Nov 16, 2005 08:44 PM
EOLJR
Oct 1, 2005 05:04 PM
classybenz1
Jun 2, 2005 03:40 PM
bazzle
May 1, 2005 09:07 AM
