INTERMITTENT STARTING PROBLEMS
Hello
ITS BEEN 8 DAYS NOW AND NO PROBLEMS
LOOK AS IF IT WAS THE CRANK POS. SENSOR
AFTER ALL [:@]
MANY THANKS TO ALL - ESPECIALLY SLEEPWALKER[sm=itsok.gif]
MIKE[sm=thanx.gif]
AFTER ALL [:@]
MIKE[sm=thanx.gif]
ARRRRRRRRRGGGGGGGGGHHHHHHHHHThe problems back again ?????[:'(] [:@]
engine wont turn over - again !!!!
Car on recovery truck back to dealer [&o]
SLEEPWALKER ARE YOU OUT THERE - HEEEEEEELLLLLLLLP
Hi Sleepwalker,
Been following this one.
CPS?
= Engine Management System?
= Central Protection System?
I'm not familiar with all these MB acronyms. Please advise true translation.
I thought the motion sensor was intro at 2000 f/l.
I ask because I am still trying to sort out WHY I have the Interiuor Light / Security problems we have disscussed previously.
I'm confident that changing the PSE will solve matters but its the WHY I remain interested in.
CPS?
ORIGINAL: Laterthatsameday
relay k40, in right module box-eng compartment---- next time it won't crank, tap on the relay,then try.
GOT CAR BACK TODAY 21 MARCH
YOU MAY BE CORRECT LATER -COS THE ENGINEER HAS REPLACED
RELAY part no. DA210 540 00 72 claiming that a soldered joint
had a microscopic crack And when he tapped relay the car cut out?
COST £72.57 ($135) TOTAL SO FAR £479 ($886) [sm=boosign.gif]
I HOPE THIS IS THE END
Yes, the same thing happened to me today on the way to work. Engine just shut off. Would not restart. All lights seemed to work, fan, radio, windows all worked. Tried several (6-8) times to restart. The engine would not crank over at all. It was towed to dealer and promptly started. I have a 2000 SLK with 23000 mi. It is now with dealer. I will update you when I get it back to see what they find. bb
