High Beam Indicator went out
Old Sep 10, 2012 | 09:13 PM
roboteacher's Avatar
Default High Beam Indicator went out
Has anyone ever changed any of the indicators on the dash. My high beam indicator stopped working and I'd love to get it back if it's not too involved.
Old Sep 13, 2012 | 06:51 AM
brookings's Avatar
what year is it?
Old Sep 13, 2012 | 04:34 PM
sorry, it's a '99.
thanks
Old Sep 13, 2012 | 07:04 PM
chassis221's Avatar
Originally Posted by roboteacher
sorry, it's a '99.
thanks
yup the bulbs can be replaced, its just a matter of getting to them. the SLK had the hardest cluster to remove out of any Benz. if you get the cluster out you can get the bulbs. but you might have to get them from the dealer.
Old Sep 14, 2012 | 05:10 AM
brookings's Avatar
you have to drop the lower half of the dash by removing the screws underneath. use a mirror with a flashlight to find them. one in the knee pad on the right side way up in a hole. one in a squared slot just behind that screw and off to the left a bit. one by the hood release. the others underneath are easy enough to see. remove a screw at the top and inside of the vent, pry the vent light switch cover off and remove the screws that hold the illumination module to the dash. use a butter knife with tape on the tip, if you don't have the proper tools, to keep from scratching dash parts. open the dash side panel, the panel with the large flat head plastic screws, and remove screws to the dash parts above and one below to the rear of the fuse panel. remove the u shaped cover just under the steering column and remove the two screws there. you must be very careful with these dash parts, they are very brittle. pull down on the lower portion of the dash. this will expose the screws for the instrument cluster cover. there are four clips at the top off the cover, use your wedge or butter knife go down between the dash and the cover to unclip. careful, careful, careful. now the book says you have to remove the streering wheel to remove the cluster to access the bulbs. however, I was able to pull it out just enough to reach behind and remove the the bulb with an aligator clip or the proper merc tool made for that purpose. Just use a mirror and a flashlight before you go in, so you can see what you're up against. cover your streering wheel with a towel so the cluster doesn't scratch it. if you take it in, it shouldn't take someone who knows what they are doing more than a hour and a half tops.
Old Oct 1, 2025 | 06:05 AM
Tornadofist's Avatar
Funny how small details can make a big difference just like with cars, the right tool in the kitchen changes everything. I recently got myself a meat knife from Cutluxe, and honestly, it’s been a game changer. It feels solid, super sharp, and slices through large cuts with zero effort. Truly, Тhe Butcher’s Trusted Tool in Your Kitchen. I ordered it from meat knife , and I couldn’t be happier with the result. The quality is on point, the balance is great, and it’s way better than the overpriced knives I’ve tried before. If anyone’s looking for something reliable and built to last, I’d definitely recommend checking them out.
Jimshipp
Aug 18, 2023 12:19 PM
fwspielmann
Jul 7, 2012 11:07 AM
jnissen
Nov 4, 2010 08:20 PM
KCMO
Sep 8, 2007 08:59 PM
light
Mercedes A Class
Jun 4, 2007 02:18 PM
