D.A.S
Old Aug 17, 2006 | 08:16 AM
PanzerKlyde's Avatar
Default D.A.S
Hi Bazzle...
I have just finished with my trans and now the car won't start !! Suck [:@]!! I can hear the starter clicking, but that's all, then msg "Starter Error" shows. I notice a similar problem posted here......something with the D.A.S and key barrel. I like to try replacing that DAS thingy, but what does it look like.....?? I need to get this problem correct so I can go to work, otherwise.....I'm stuck. Can you help me!! Thanks.
Old Aug 21, 2006 | 03:41 AM
snanceki's Avatar
Default RE: D.A.S
If the Starter or Starter Relay are clicking it unlikely to be the DAS.
Where is the noise coming from? If its the Relay try giving it a tap or replace it.
If its coming from the Starter have you checked that your Battery is OK?
Stuart
Old Aug 23, 2006 | 10:45 PM
Default RE: D.A.S
I followed your lead..... the noise came from the starter.. and It was my battery........being near Dead !! ....
Many thanks.... Stuart
