CODE: P0170 & P1584
I was able to google it up and P0170 says "intake leak, AIR system, fuel pressure/pump, injectors(s), EVAP canister purge valve, HO2S" With this, I don't know what it means. Which parts should I replace? What was the problem?
I wasn't able to get find P1584.
Got me. I was just telling BikerDrew he could Google up a list of codes.
Sounds like a few things could be wrong, all of which boils down to a leak somewhere in the air or fuel intake flows. Is the CEL light still on? Was it turned off by your mechanic and then it came back on?
Yes, my mechanics turned off the CEL, but it comes on again after 2-3 minutes after I drive off.
What would you recommend me to do?
P1584 - stop lamp switch. Do you know how much is it to replace?
