blinkers stay solid
Old Aug 26, 2012 | 04:30 PM
roboteacher's Avatar
Default blinkers stay solid
'99 slk230. blinkers come on but don't flash. they stay on solid. is there a flasher relay (like the old school GM vehicles)? If not, where should i look?
thanks
Old Aug 27, 2012 | 08:01 AM
FYI:
I turned the ignition ON
Cycled the hazards 2 times
The blinkers and hazards began to work
This must have been because I changed the battery
Old Sep 2, 2012 | 11:18 AM
SLK230inFL's Avatar
Hey roboteacher,
I had the same issue with my 98 SLK230 and shortly thereafter had problems with stalling and starting the vehicle. All were connected to the K40 relay which I replaced. It's been a month without trouble. Something to keep in mind if you start to experience those problems.
Old Sep 3, 2012 | 07:39 AM
Default the real fix
I actually have now done this proceedure SLK Indicator lights staying on - Possible fix - Benzworld.org - Mercedes-Benz Discussion Forum and it worked great. I have replacement relay on its way and as soon as I get it replaced, I'll be golden. Thanks for the heads up.
DRPRJOHNSON
Apr 16, 2011 10:19 AM
DoubleNickle
Apr 21, 2008 10:17 PM
rkrose
Jan 24, 2008 06:44 PM
saraya
Nov 17, 2006 12:57 AM
ARMENDS500
Jul 14, 2006 10:09 PM
