BAS/ESP_ABS, Tranny, Electrical
Old Jun 6, 2008 | 03:32 PM
JAKO's Avatar
Default BAS/ESP_ABS, Tranny, Electrical
2) BAS ESP ABS Intermittent ON/Off_________(possible battery charge? i read under 10 amps the all shut off automatically)
3) Slips from Reverse to Nuetral(3 time total), tiptronic would not engage(once)________(tranny...please no, speed sensor?)
4) Blinking trun signals after lock________(no idea!)
5) interior autmatic dome light problem_________(battery drain? related to 1&2?)
6) ashtray replacment?
I Know this is a lot, and I appreciate anyones help, suggestions, or input. I just don't know what to do, nearest MB dealership is 3 hours away. I just want to be happy, I love the car and it has extreme sentimental value to me and my family.
Evan
HELP MY Kompressor!
Old Jun 9, 2008 | 12:30 AM
snanceki's Avatar
Default RE: BAS/ESP_ABS, Tranny, Electrical
2. Yep battery MAY be problem.
Need to enure that battery voltage and charge rate are OK.
Start by placing a volt meter across the battery with engine off, engine running idle, engine running 2000 revs and then all again with the headlamps fulls on.
Results?
ABS is a voltage sensitive system.
Mileage / age / battery age???
5. Quite possibly the PSE. Common problem. Describe the problem in more detail to confirm.
6. Ash tray or trinket/cup holder?
If former remove the radio to start the diassembly process.
If the later this is a major job!!
3 and 4 MAY be linked to the PSE problem.
Stuart
Old Jun 9, 2008 | 01:11 PM
JAKO's Avatar
thanks stuart!
There were some problems with the upload thing, I will try to post the whole message again and hopefully it works.
Evan
CHRISeBOY
Jul 10, 2006 12:39 AM
G4ME
Jan 2, 2004 02:12 AM
mellen
Sep 25, 2003 04:21 PM
Jonnyo
Sep 2, 2003 11:45 AM
