2001 SLK230 Transmission is in Emergency / Limp mode
2001 SLK230
Fault codes:
This makes me suspect my ETC / EGS is bad.
Found used ETC / EGS on flee bay matching P/N’s. States it is from a E class located in Kaunas, Lithuania.
Ebay P/N: A0305452032 EGS52 5WP2 0000AR 01W15 Q03
My ETC / EGS: A0305452032 EGS52 5WP2 0000AR 01W18 Q03
Please let me know If you think my ETC / EGS is bad?
Also will the Ebay item work without reprogramming?
Thanks,
- 722.6 (5 speed) transmission.
- ETC (EGS) N1 5/3; EGS52
- A0305452032 EGS52 5WP2 0000AR
Fault codes:
- P2026-016 CAN message from control module N1 5/3 (ETC [EGS] control unit) CAN signal interruption [P0600]
- B1039 Fault in CAN communication with control unit Transmission control.
- Purchased transmission dipstick and checked fluid level = Good / Full.
- Checked Mercedes Transmission 13-Pin Connector Adapter Plug + O-rings.= Good / no leaks. Replaced anyway with NEW.
- Did complete transmission flush (9 qts) Dropped / cleaned pan, changed filter. Added back the same amount removed from pan. Placed cooler return line into container and removed / added 1qt at a time. Flushed 9qts total.
- Brake pedal switch checked = Good. Replaced with NEW anyway.
- Checked Conductor plate / valve body from ETC connector = Good.
- Scanner reads all shift positions (P/D/R) and sensors as good. (wheel speed sensor = good)
- CAN Bus wires @ ETC / EGS measures 60 Ohms = Good.
- Both 12V power and Gnd are good to ETC / EGS
Thanks,
drew34drewbie@yahoo.com
Jun 17, 2009 01:38 AM
OrangeCountyGirly
Nov 21, 2007 02:36 AM
