Vacuum line
Old May 21, 2011 | 08:26 PM
sl owner's Avatar
Default Vacuum line
The vacuum line from the air pump located on the bottom right of the engine has come disconnected, on the other end, and I can't find where the line attaches. I have a 85 380 SL. It looks like it attaches somewhere on the top of the engine but where? I've looked at diagrams but they don't give a location for the components. Is there any photos of vacuum line locations?
Old May 22, 2011 | 01:53 PM
brookings's Avatar
normally it would attach to an air shut-off/blow-off/diverter/by-pass valve called by various names. you might look under the exhaust manifold. go to autohausaz.com and go to your model of car, go to emmisions and click on air/smog pump check valve to see what it looks like.
Old May 23, 2011 | 07:18 AM
sl owner's Avatar
Default vacuum line
Thanks for the info but It's the other end of the vacuum line that came unattached.
Old May 24, 2011 | 03:46 AM
brookings's Avatar
you don't see a solid pipe coming out of the block and going under the exhaust manifold? my sl is a 129 and is not the same engine, but generally they should be simular in emission control. mine comes out just above the exhaust manifold mid-engine and goes down and under the manifold to the by-pass valve then to the pump. you might want to subscribe to alldata.com. it can come in handy for things like this.
Old May 25, 2011 | 03:18 PM
sl owner's Avatar
Default Vacuum line
Can't find any solid line coming out of block. Do you have a photo?
Kevin Rattai
Oct 2, 2013 04:56 PM
Ashey
Mar 3, 2004 03:09 PM
porscheturbo
Mar 3, 2004 12:47 AM
vapalux
Mar 1, 2004 02:39 AM
Lugnut
Jan 23, 2004 11:10 PM
