Trans linkage on 79 450 SL
Old Jul 8, 2005 | 03:34 PM
hippie13's Avatar
Default Trans linkage on 79 450 SL
I am getting a bit of slippage when I move from gear to gear, any ideas on how to prevent or cure this problem?
Old Jul 8, 2005 | 06:22 PM
Benzbob's Avatar
Default RE: Trans linkage on 79 450 SL
Sounds like what you mean is called "flaring". Does the engine race for a second between shifts? If so, this could be a stuck modulator valve. The modulator valve is located on the drivers side of the tranny and is connected by a single vacuum hose. This devise dampens transmission shifts between gears, as without this modulator valve, shifts would be harsh, or bang hard into each gear. They can become stuck open and cause flaring, or a leak in the vac hose would render harsh banging shifts. Low transmission fluid, or clogged tranny filter, can cause flaring too, so check that first, second I would begin looking at the modulator valve. Beyond that, I would have a specialist determine cause. [&:]
oldschool
Apr 27, 2026 06:12 AM
cliff
Jan 1, 2009 03:55 PM
Jay Carnes
Aug 2, 2005 08:04 AM
Jay Carnes
Jul 20, 2005 02:58 PM
cam69ss
May 19, 2004 02:27 PM
