Switch on emergency brake
Old Nov 5, 2011 | 05:24 PM
Joseph Ball's Avatar
Default Switch on emergency brake
There is a switch that turns on the brake indicator light when the emergency brake is on. It is a 1975 450SL. Does anyone know where the switch is located and how to get at it?
Old Dec 15, 2011 | 08:10 PM
96SL500's Avatar
From: Manatee County, Florida- Sarasota mailing address
More than likely the switch is just above the pedal arm (if you have a foot brake) just like current model rear brake lights work. The switch will be bolted to the frame. Good luck
Old Jan 6, 2012 | 08:22 PM
Arildo's Avatar
Today - actually, I was removing the vacuum brake drum (lying 180degree of normal, with my foot up in the air) in the cockpit. I was curious about the park brakes as well, and found out it's a little switch at the end of the "hand brake" pedal that do the switching. It's a one wire only (the other one go trough the chassis). Its looks like very easy to replace (but you must be an acrobat - like me!)
brudd
Feb 16, 2009 10:56 PM
brudd
Feb 10, 2009 09:51 AM
rgengr
May 27, 2008 09:44 AM
rosenfe
Mar 19, 2008 07:46 PM
brudd
Jul 17, 2007 10:06 PM
